Bài viết này sẽ hướng dẫn các bạn cấu hình Vlan routing trên thiết bị Switch Huawei theo mô hình ví dụ phía dưới. 1. Tạo Vlan trên các switch và đưa port vào Vlan trên switch 2 và 3 : + Switch 1 : <Sw1>system-view [Sw1]vlan 10 [Sw1]vlan 20 + Switch 2 : <Sw2>system-view [Sw2]vlan 10 [Sw2]vlan 20 [Sw2]interface GigabitEthernet 0/0/1 [Sw2-GigabitEthernet0/0/1]port link-type access [Sw2-GigabitEthernet0/0/1]port default vlan 10 [Sw2-GigabitEthernet0/0/2]quit [Sw2]interface GigabitEthernet 0/0/2 [Sw2-GigabitEthernet0/0/2]port link-type access [Sw2-GigabitEthernet0/0/2]port default vlan 20 [Sw2-GigabitEthernet0/0/2]quit + Switch 3 : <Sw3>system-view [Sw3]vlan 10 [Sw3]vlan 20 [Sw2]interface GigabitEthernet 0/0/1 [Sw2-GigabitEthernet0/0/1]port link-type access [Sw2-GigabitEthernet0/0/1]port default vlan 10 [Sw2-GigabitEthernet0/0/2]quit [Sw2]interface GigabitEthernet 0/0/2 [Sw2-GigabitEthernet0/0/2]port link-type access [Sw2-GigabitEthernet0/0/2]port default vlan 20 [Sw2-GigabitEthernet0/0/2]quit 2. Cấu hình Link aggregation và trunking : + Switch 1 : [Sw1]interface Eth-Trunk 0 [Sw1-Eth-Trunk0]mode lacp-static [Sw1-Eth-Trunk0]trunkport GigabitEthernet 0/0/3 [Sw1-Eth-Trunk0]trunkport GigabitEthernet 0/0/4 [Sw1-Eth-Trunk0]quit [Sw1]interface Eth-Trunk 1 [Sw1-Eth-Trunk1]mode lacp-static [Sw1-Eth-Trunk1]trunkport GigabitEthernet 0/0/5 [Sw1-Eth-Trunk1]trunkport GigabitEthernet 0/0/6 + Switch 2 : [Sw2]interface Eth-Trunk 0 [Sw2-Eth-Trunk0]mode lacp-static [Sw2-Eth-Trunk0]trunkport GigabitEthernet 0/0/3 [Sw2-Eth-Trunk0]trunkport GigabitEthernet 0/0/4 + Switch 3 : [Sw3]interface Eth-Trunk 0 [Sw3-Eth-Trunk0]mode lacp-static [Sw3-Eth-Trunk0]trunkport GigabitEthernet 0/0/5 [Sw3-Eth-Trunk0]trunkport GigabitEthernet 0/0/6 - Kiểm tra cấu hình vừa tạo. - Cấu hình interface Eth-Trunk là port trunk và cho phép vlan trên nó. + Switch 1 : [Sw1]interface Eth-Trunk 0 [Sw1-Eth-Trunk0]port link-type trunk [Sw1-Eth-Trunk0]port trunk allow-pass vlan all [Sw1-Eth-Trunk0]quit [Sw1]interface Eth-Trunk 1 [Sw1-Eth-Trunk1]port link-type trunk [Sw1-Eth-Trunk1]port trunk allow-pass vlan all + Switch 2 : [Sw2]interface Eth-Trunk 0 [Sw2-Eth-Trunk0]port link-type trunk [Sw2-Eth-Trunk0]port trunk allow-pass vlan all + Switch 3 : [Sw3]interface Eth-Trunk 0 [Sw3-Eth-Trunk0]port link-type trunk [Sw3-Eth-Trunk0]port trunk allow-pass vlan all - Kiểm tra cấu hình vừa tạo. 3.Cấu hình địa chỉ IP cho interface Vlan 10 và 20 : [Sw1]interface Vlanif 10 [Sw1-Vlanif10]ip address 192.168.10.1 24 [Sw1-Vlanif10]quit [Sw1]interface Vlanif 20 [Sw1-Vlanif20]ip address 192.168.20.1 24 - Kiểm tra cấu hình. 4.Kiểm tra kết nối từ trên Host : - Kiểm tra kết nối từ Host 1 đến các Host còn lại. !!! Cảm ơn các bạn đã theo dõi bài viết !!!
