Eaton - UPS 3 pha, công suất từ 10kVA đến 40kVA.
Thảo luận trong 'Thùng rác' bắt đầu bởi huyvu1321, 3/12/20.
  1. huyvu1321
    huyvu1321 Member
    Eaton kính gửi quý đối tác thông tin về các dòng UPS Eaton 3 pha, có công suất từ 10kVA đến 40kVA:
    I. UPS dạng khối
    1. Eaton 93E:
    • Power Rating: 15,20,30,40 kVA (Up to 500kVA)
    • Topology: Double-Conversion, Transformer-Free.
    • Input/Output Voltage: 230/400 4 Wire
    • Frequency: 50/60 Hz
    • Hot Sync® Parallel Technology, ABM®
    • High Efficiency(HE) Mode, Easy Capacity Test
    • UL cybersecurity for SNMP card
    Link: http://powerquality.eaton.com/Produ...=46&GUID=04FBF974-26F5-49EE-86AD-B04089DDEC0E
    1. Eaton 93 EXL:
    • Long backup time with internal battery
    • Battery Tray for easy installation and replacement
    • Flexible configuration for back-up time
    • Internal battery breaker & MBS
    • Optional Back Feed
    • 0.9pf out@ 40oC
    • ABM Cyclic Charging technology
    • Hot Sync parallel technology
    • External paralleling up to 6 systems
    • 94% Eff. Double Conversion/ 98% Eff. HE Mode
    Link: http://powerquality.eaton.com/Products-services/Backup-Power-UPS/93EXL.aspx?cx=46
    [​IMG][​IMG]
    1. Eaton 9355:
    • Power Rating: 8,15,20, 30, 40 kVA
    • Internal battery approx. 10 min at full load approx. 25 min with half load. Backup time extendable with external battery cabinets
    • Features ABM and HotSync to enhance reliability and availability
    • Enterprise connectivity and software solutions to fulfill user’s needs – two x-slots as standard, UL cybersecurity for SNMP card
    II. UPS dạng Modular
    1. Eaton 93PS:
    • Highest efficiency of 96% on-line mode
    • Patented Eaton Hot-Sync Parallel Technology
    • Patented Eaton Advanced Battery Management
    • ESS technology(highest efficiency of >99%)
    • VMMS technology(highest efficiency at low load)
    • Easy Capacity Test (ECT)
    • Parallel Different Capacity
    • Shared or Individual Internal battery string(Only for 30/40KW)
    • Compact space saving
    • Scalable/Modular/Hot-Swappable(Only with 2 Modules)
    • Advanced LED stripe display
    • 5” LCD touch-screen colour front panel display
    Link: https://www.eaton.com/nz/en-gb/cata...stribution/eaton-93ps-ups.specifications.html
    1. Eaton BladeUPS:
    • Power Rating: 12kW to 60kW
    • Efficiency: with >97% efficiency will help reduce power and cooling requirements.
    • Flexibility & Scalability: Ability to flex the power system to meet changing business requirements.
    • Reliability: Highest reliability design, using proven technology from mega data centre UPS designs… made easy for the IT end user.
    • Power Density: 60kW N+1 in a single 19” enclosure, maximizes datacenter space for revenue generating business requirements
    • Hot Sync® technology, Eaton's advanced battery management. ABM®, Hot-swappable electronics and battery modules.
    Link: https://www.eaton.com/us/en-us/cata...istribution/Eaton_BladeUPS_UPS.resources.html
    [​IMG][​IMG]
    Chân thành cảm ơn.
    Tel / Zalo: 0917684899
    Email: info@thegioimang.vn
    About UPS Eaton
    Eaton’s mission is to improve the quality of life and the environment through the use of power management technologies and services. We provide sustainable solutions that help our customers effectively manage electrical, hydraulic and mechanical power – more safely, more efficiently and more reliably. Eaton’s 2019 revenues were $21.4 billion, and we sell products to customers in more than 175 countries. We have approximately 101,000 employees.. For more information, please check https://www.eaton.com/us/en-us/company/about-us.html
